tow/haul button
hello gang. i did some reasearch on the tow/haul mode and didnt really see anything that might help my question.
I just bought a 2003 Sierra SL (work truck and yes, they do come with vinyl flooring!) with the Vortec 4800 and four speed auto.
on the gearshift, it has the button for the tow/haul mode and the picture of the trailer on the gearshift as well.
i looked it up in my manual and saw the light for the mode on the instrument panel but mine does not work.
could this be because it is not installed but the button is just there???
any thoughts or suggestions? this is my first "newer" truck.
thanks all.
Lee
thanks all.
Lee
You should be able to tell by the way it shifts. It should hold the gears longer and shift a little harder. If that doesn't happen then something is amiss.
There is no change at all when the button is pushed. i was at a stoplight and pushed it..didnt see a change. got to another stop light and pushed the button again, still, shifted the same....
could it be a fuse?
Lee
Thats right, I forgot someone did say the wire got broke for their tow haul. It was down in the steering column close to the pivet.
CHEEKSTER................Does the little light that looks like a
trailer light up (its on top of the speedo numbers...on the
right) when you push the tow/haul button on?
......................geo
sonjaab...i get no light on the dash. i looked it up in the owners manual...saw where the light is at and i do not get it when the button is pushed.
i looked under the steering column and then under the dash and didnt see anything out of the ordinary. i still have a warranty from the dealership..is this a big issue or should i just go without? i dont plan on doing any major towing (maybe my 3500# boat in Drive).
i use all my heavy hauling and towing with my K20 and she doesnt break a sweat. granted, i dont go past 55 with it. 235/85/16 tires, 4.10s and the TH400..makes the engine wind up a bit im sure.
any more recommendations?
Lee
If it is under warranty, why not get it fixed?
:confused: If you still have the warranty take advantage of it. No reason to not have this feature for the life of your truck when you can get it fixed now at no cost.
LEE....................NO little trailer icon light huh?
Best off checking the fuse center(s) for a
popped fuse before ya hassle with the dealer.
Owners manual will/should show what fuse it is.
But if its not a fuse......WARRANTY TIME !
I love the tow/haul mode for plowing snow. Keeps the
tranny in 1st during a long push instead of it shifting back
and forth or hunting between gears shoving the HEAVY
"white gold" !!!!............geo
Never had that problem with my trucks and none of them have a tow/haul button but none of them are 1/2 tons either. My heavy trucks never seem to even break a sweat even when stacking it too.
I ll go out and check the fuse panel now and look in the owners manual for the fuse(s).
If i dont find any blown fuses, then i will take the truck to the dealership. The front end is also making some grinding sounds when the brakes are applied. They put on new breaks in the rear (not sure if it was just pads or rotors and pads) but never the less, put on a new inpsection sticker for me.
The warranty is only good for 30 days/1000 miles. i wont sit on it.
i ll keep all posted..
thanks.
Lee
ps..how soft is the break pedal suppose to be? mine is pretty soft. it doesnt go to the floor, but it does seem alot of effort is required to stop the truck.
my 87 K20 (13" drums in the back) uses hardly any break pressure to stop the truck down.
Lee
well, went fiddling around the THREE fuse blocks in the truck, went thru the owners manual looking at all the fuses and their definations. not one said anything about the tow/haul. saw one for the tranny (safety switch where you cant start in drive).
i ll just end up taking it to the dealer.
Lee
    Kirk Belch
    Kirk Belch
  • Who's Online   4 Members, 0 Anonymous, 1,218 Guests (See full list)
