Lights flicker on 97 Sierra
On my 97 Sierra with 237,000 miles when the outside light is low you can see all the lights flicker. Also the volt gauge moves up and down withing one line real fast. Any ideas?
I would check your body to frame to battery ground return straps and also check all connection that you can in the main power buss and check altenator function too.
I will give that a look, thanks.
