MSUChevyMan Posted April 24, 2005 Posted April 24, 2005 Ok, I'll set this question up a bit. Here in Michigan we've had a lot of warmer-than-normal weather, and it recently has dropped back into the 30's with snow. Went out to drive my truck tonight after it sitting for a few hours, and as I pulled out of parking spot, it felt like I had no power steering. I had to use two hands to start turning, and halfway through my turn it kicked it. It was fine the rest of the drive. Has anyone ever had a problem like this? Could the cold weather have an impact? I'd never had trouble with it before...Thanks!
seadoons Posted April 24, 2005 Posted April 24, 2005 I have a 2002 Z71 and have also experienced this problem. Check your power steering fluid level and add some if necessary. I topped mine off and it seemed to stop doing it. I also noticed mine will do it if the idle level drops too low.
MSUChevyMan Posted April 24, 2005 Author Posted April 24, 2005 Thanks seadoons, I'll check that out and go from there.
Worktruck Posted April 24, 2005 Posted April 24, 2005 My 02 Sierra will do this also, usually when going into reverse. I always back into my driveway and when I first start back and turn it seems to have no power steering. I have checked the fluid and it is ok. But the idle does drop real low at that time.
