HELP! Dead on the road!
HELP! Yesterday I was coming home, minding my own business, :D when all of a sudden she just DIED! Not a miss, not a stutter, NO warning at all, it just went completely dead! Ok, the truck: 98 Chevy 1500 ext. cab Z71, 5spd, 5.7 liter engine, 132K miles. I called a mechanic buddy of mine to see what he could come up with from 60 miles away and he suggested 1 of 3 things: distributor cap and rotor, coil, or crankshaft position sensor. Ive changed 2 out of the 3, I didnt change the coil, BUT I am getting fire to the cap AND to the plugs, so I dont think it is the coil!
I ended up trailering it home late last night, but MAN I need this truck back up and running by Monday! Any suggestions?
For an engine to run, you need spark at the right time, a decent fuel/air mix in the cylinders and compression.
What's missing? You say you have spark, and I think we can assume it's at the right time. Compression doesn't just suddenly go away.
So that leaves fuel/air. Do you have fuel pressure?
Is there a way a shadetree mechanic can check fuel pressure? I removed the cap off teh line at the back of the throttle body and depressed the valve. I DECENT fuel spray emerged, then I had my wife crank the engine over while I depressed the valve and I had fuel, just NOT as much as I thought I should have. it was about like a weak drinking fountain. WILL a fuel pump going out go ALL AT ONCE like that and then NEVER even TRY to start back up? These electronic in tank pumps are new to me, but on a good old 350 small block, a pump doesnt normally die without ANY warning!
Also, when I turn the key to "run" position, I can hear the pump run for about 4 or 5 seconds so I know the pump is getting power.
yea, that happend to me. 94' 4.3L V6. It would start one time and the next time it was zilch. The main difference is that my pump wouldn't run briefly before startup, so I knew right then thats what it was. I would still say your fuel pump could be going, but I can't explain why yours will wind up like that as if it was working properly.
Will a fuel filter prevent start up, or just hurt performance?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
