Engine tremble?
 I just bought a 01' Siverado LS.  Its a dream come true...  except for the motor.  I have the 4800 in it.  The problem is that the motor has a slight miss or something that is noticeable at idle.  I took it back to the dealer and of course " they all do it" he said.  I insisted that he prove this, and we took a ride in another truck and sure enough it did it as well.  Not as pronounced as mine though.  He called it a slight "tremble" at idle that is caused by a lean condition at idle.  This sounds like complete B.S. to me.  My 68 purs like a kitten never skips a beat.  Anyone else out there notice this on your trucks (99-01)?  Seems to me that by the year 2001 they could make an engine run a #### of a lot smoother than that!
First off,welcome to the site!
Senondly,from my expierences with the fuel injected GM trucks,your dealer is telling the truth,they ALL do it.
I have a 2001 Silverado work truck with the 4.8,my youngest brother has a 2000 Z71 5.3,the wife's 5.7 '99 Tahoe and my mothers '99 5.7 Suburban all have the same "idle hesitation" that you are describing.My tbi '93 did the same thing as well so it's probably something that you'll just have to deal with.
My '00 will wiggle the tip of the antenna at a stop light.  It idles at a pretty low RPM when in gear and that may be part of the problem...  It doesn't show any stumble or hesitation when I step on the gas though, (if it did I would be very concerned).
By the way...  welcome!!!
I wanted to let you know a friend of mine just bought a used '99 Z71 excab with the 4.8L and his first tank of fuel netted 18.5mpg!!!  The truck has 45,000 miles on it!!!  (I'll ask him at work this week if his truck shows any of the same signs as yours)
This is a common problem with the Vortec engines, dating all the way back to '96 when they were introduced.  You see...in order to minimize hydrocarbon emissions and maximize fuel economy they have these trucks dialed in pretty lean, and the idle is VERY low when compared to older trucks.  This results in a bit of a miss at idle, although some trucks are worse than others.  My '96 was pretty bad.  I tried several times to get the dealer to reprogram the PCM to fix it, they kept saying it was out of warranty.  Well, you guys are gonna love this one.  About 1000 miles after the warranty ran out the O2 sensor died on me.  Took it to the SAME dealer I bought the truck from, which was the same dealer I had been pestering about this problem for more than a year.  What did they say...the O2 sensor was bad AND for ? they needed to reprogram the PCM!!!  I hit the ROOF!  I got them to replace the O2 sensor for the cost of the part, but they never would admit that the PCM really needed to be reprogrammed, nor would they do it for me.  This is such BS.  Anyway...
I _think_ that if you bought a HyperTech power programmer that you could fatten up the fuel curve to include idle, and lose some of that miss.  Otherwise, you'll have to live with it.
I find a certain satisfaction in the fact that my '76 Sub 454 idles smoother than my '96 GMC Vortec ever did.
Jeff
yeah, the pcm update for the 96 and 97s helped out quite a bit with drivability issues.  the dealer should have done that.
as far as the hypertech goes, they cannot change anything that goes on in closed loop, therefore cannot do anything to the fuel control at idle.
besides, with fuel prices the way they are, i would love to have that lean idle to help me get better mileage.
    TopBo
    TopBo
  • Who's Online   3 Members, 0 Anonymous, 1,275 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
