Wanted: Fuel Pump for 5.3L
I am pretty sure I've got a bad fuel pump.......
Have you had your fuel pressure checked? It could be something else that is way cheaper. Shouldn't cost much if anything to have it checked.
Once I was sure I blew my motor cuz it had no power, but it turned out I left the E-brake on. :driving:
I have a 2001 fuel pump.  I'm not really sure how I got it.  I may have bought it for my truck a few years back but just never really used it.  Email me if you are interested.  [email protected]
I will be emailing you when I get home from work
Also, I've had the pressure checked, and it drops below 20 psi up in higher RPM's. I also lose my prime once I shut the truck off....
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
