Hail protection
carbuster
Anybody else think it's a little odd that he goes to all that trouble, when all he had to do was pull the truck into the garage?
:thumbs:
The pic of his garage looks pretty much like. I have too much stuff in there to put the truck in the garage. If it is suppose to hail I just park mine under the back porch.The bed of the truck sticks out but it is better than no cover at all.
Yeah he couldn't pull into the garage. Too full. He did that just for fun. It's no house air conditioner installation, but it's still pretty funny, especially with leaving that civic the way it is. You can see where the priorites lie. :thumbs:
looks like a baked potato
:puke::thumbs::D:thumbs::D:lol::D
I used to grab the quilts off my bed when it got to hailing bad here in Denver, and throw them on the hood and roof. Got a garage now, makes life so much simpler.
