New Exhaust for the Bravada
I decided to get some exhaust for my 2004 Bravada, and when we mocked it up to come straight out the back it looked funny, so I went with a side pipe. Tell me what you think!
Looks good. I think you made the right choice in going out the side with the design you have. Did you replace everything from the Cat back? How is the sound? Any resonance?
It's a full Magnaflow exhaust and it sounds amazing. Not a loud rumble but has a nice "growl" to it. Sounds a LOT better than stock and looks better too.
Looks Good.....might have to look into that for my Bravada. :D
Not to get off the subject here but how is your Bravy now that you had everything replaced? Mine still makes the clunk noise and my dealer says that is a characteristic of AWD vehicles...?
It runs real minty now that everything was replaced. The drive now is what I would have expected from a Bravada. Much more smoother, seems to be able to use the power more efficiently, and is a much more nicer vehicle to drive than before.
Is this a kit or did the muffler shop fab it together for you? Any in cabin resonance at 1500 to 2000 rpm's in drive?
It was a complete kit from what I understand. I just went into this exhaust shope that came highly recommended and told them what I wanted and they had me in and out within a short period of time. I watched them do the work and they were very quick with it.
Not sure by what you mean by resonance, but I have alot of aftermarket sound deadening added to my vehicle and when I accelerate you can hear the growl from the exhaust. Makes me smile from ear to ear lol.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
