Guys who went from 16's to 20's...
did you notice any change in gas mileage. Right now i have a 03 gmc with 5.3l and 16 inch rims and tires, stock setup. I am getting pretty good gas mileage and want to know if there is any difference with the bigger rim, looking to keep the rolling diameter close, maybe go up 1 inch.
Thanks
one thing remains true. "Ya gotta pay to play" I dont notice any difference, but then again I drive it like I stole it. Otherwise whats the point of having a v8 if you dont use it? That d**n GOVERNER pisses me off. 100mph? why slow down there. Give me just a little more come on baby!
That 100mph limiter is super easy (not to mention free) to get around. Just drive it off a cliff. I bet you hit 300mph.
Kind of sucks though, it only works once.
  • 1 year later...
  • 5 weeks later...
I ordered my 20"s today with 305/50 tires, Ill have to see if my mileage changes at all. I tried one on my truck and I'll tell you one thing, they weigh about twice as much as my stock aluminum 16"s
I changed my wheels from the stock 17s to 20s, and am getting slightly worse gas mileage... not a huge difference though maybe 1mpg. I thought that it wouldnt change, because the diameter of each was very close to the same with the tires included.
On a different note, what is the biggest tire you can fit on an 5 sierra stock 17" wheel without rubbing or interfering with anything? Anyone know? I was thinking I might be able to squeeze some 305 or 295 60s... What do you think??
  • 1 month later...
Ive had my 20s for about 3 weeks now and I havent really noticed a change in mileage. Maybe .5 to 1 mpg, definitely worth it though because it looks 10 times better!
My dad has 285/75/16 on his Suburban and they dont rub but that has a different front bumper. 285/75/16 is a 33" inch tall tire so I wouldn't go any bigger than 295 or 305/65/17 as it is 32.8"
:cheers:
Just put 22's on my 04 Tahoe...305/40/22 tires. Haven't noticed any difference, then again, these are taller, and my speedo is 3% off, so mileage might be fooled for now.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
