dash light dimmer switch STRANGE HAPPENINGS
ok, i had the strangest thing happen to me last night -
i'll preface by saying the dash is stock, no aftermarket lights, indiglo or any of that cr@p.
so, i "remote started" my truck last night and got in, turned on the A/C and jumped on the freeway - i then noticed that my dash lights were't working, so i moved the dimmer switch to the point where the lights were on BUT they were at their brightest point, so NO dimming available
The weird part is, is that when those lights came on, it felt like it triggered the HEATER to turn on - and keep in mind, i had the A/C on at the time
this is the weirdest thing i have seen yet - but for 10 years old and 195K miles, it doesn't surprise me - however it does confuse me!
anybody got any ideas - if i replace the dimmer switch will my lights come back on at low level, and stop turning my heater on? i mean, if i have to, i can buy an aftermarket "indiglo" or flame setup for the dash, but thought i'd try here first and see if anyone else had a bright idea or 2?
I'd guess you have a bad ground somewhere. Now, where, that's a dern good question...
Check for any black wires with ring terminals on them connecting to the chassis, especially up under the dash. It could also be a cracked solder joint in the heater control module, possibly on a ground pin.
What I think's happening is that the current for the lights doesn't have a ground and is going through something else (heater control) to get there.
Yeah, I think the exorcist sounds like a simpler, if not more effective solution... Sorry...
i just don't understand why the lights aren't even ON when the dimmer is all the way down - if that were the actual case - wouldn't the lights be dim and the heater on all the time when the headlights are on?
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
