I am so glad I found you guys!
First off I must say how glad I am to have found a comunity of like minded people.
Growing up I always wanted a K5 Blazer. When I finaly got to a position where I could afford to buy a vehicle I truly wanted the K5 was out of production.
The 2 door Yukon fit the bill perfectly.
I began looking and triped over a 1997 4 door Yukon (4wd 350cid towing pkg etc...) I didnt think I wanted the longer wheelbase. I now bealive I was mistaken.
I love my truck!
I don't plan on ever selling her!
A quick question. I was running some wiring for all of my power hungry toys. The next day I smell fuel. The first thing i assume is i nicked the tank with my drill. I don't think so. I lowered the fuel tank enough to get to the connections and it appears the middle fuel line is no longer connected. Even worse it is nowhere to be found. Can anyone tell me what this line does? where it might run to?
Thanks in advance!
Steve
PS I will soon lay out my overall mod plan for your apraisal and suggestions. I can not wait to see what Ideas you guys have implimented on your machines.
I love my truck!
Thanks in advance!
Steve
I'm only guessing here but it sounds like a fuel tank vent line. The best thing to do is get a shop manual for your vehicle and see if you can track it down. :chevy:
Ok I feel like an idiot.
1: I did drill a hole in the very tip of my fuel tank.
2: The center port on my fuel pump is a dummy.
So I have patched the 1/4" hole. All is well.
Thank you for your time.
Steve
Don't feel like an idiot, because you're not.
Idiots are those who break something and won't admit they did, or try to hide it.
Glad you got it fixed!
Yeah, I'm with you on the 2 door vs. 4 door part. When I bought my crew cab, I was looking for an extended cab. Now that I've had the crew for 6 months, I love it. Lots of room! You can get stuff in the back without messing with the front seat position. The dogs think they're in hog heaven now, with their own window to hang their head out and let their ears flap in the wind...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
