2000 Silverado new tire/size questions
I have steeltex a/t tires on the 2000 silverado, Z71 ext cab, 5.3l, w/ 4.10 rear end I bought last month. They are stock 245/75/16. I don't like the tires and have been thinking of getting the Revo's or the Michelin LTX M/S.
I have a 1988 K1500 that has the 265 Michelin LTX M/S, they have about 70k miles on them and have about 1/2 the tread left, I really like them and will probably be getting new ones to put on the 2000, but have read such good reviews about the Revo's I'm thinking of giving them a try. The only thing that gives me concern is the "rollling friction" I've read about that will make my mileage suffer.
I seldom tow anything, and do mostly highway driving. I will occasionally go to the beach, and do have to put up with snow occasionally (Delaware).
I'm not very tire literate, and am wondering if I should stay with the 245/75/16 or step up to the 265/75/16's? I like the looks of the larger tire. What would the difference be? I think with the larger tire, the gas mileage suffers, but with the smaller there's better handling? Somebody clue me in....
In all honesty, your "seat of the pants" won't see much difference at all. Yes, you will get a tad less fuel economy, but you won't go from 15 to 5. In my opinion, the look is worth the very small price to pay (loss in economy, break wear, final differential being taller, etc.)
I say go for it!
Go with the 265's. That was the stock size for me. I've got them in LT Revo's load range C and not a complaint at all. I'm just shy of 82k now and put them on at 36k. Plenty of life left.
Do a Search here on GM-TC for Revos to see what others on the forum have to say about them. There have been lots of posts, mostly very favorable. Shorter sidewalls result in quicker steering response for performance tires. But, with rollover concerns from a high center of gravity you don't want to subject a pickup to hard cornering anyway. For the differences in the two sizes as far as axle ratio, RPM, and speedometer reading use this link from Tirerack.com
Light Truck Fitment Formulas
Scroll down to "What is the right size for my vehicle?" on this link, info on changing from an original equipment size and Tirerack's 800# for fitment advice.
Selecting The Right Tires
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
