  • 3 weeks later...
  • 1 month later...
yes, I have an 2004 GMC Envoy SLT with the same color of your Silverado, and I'm waxing my Envoy since new with Turtle Wax.
I just waxed all 3 of my vehicles with the Turtl Wax Platinum. Great shine and it came off nice. What i didn't like is the bottle it came in. i used the liquid and there is no small flip up tab like other waxes have. It just free flows out of the wide top. Just a pain, but you probably use more than you need which is good marketing on Turtle Waxes part.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
