Improving Mileage - Which is best?
Hello:
I just picked up a 2001 Chevy Suburban (1/2 ton), and sold my 1999 Chevy Blazer. Although I have only put one tank of gas through it, I have been surprised that the mileage is significantly worse than my blazer. In mixed driving my blazer got 15, while the suburban gets 11. The blazer got 12 city, and 18-20 highway (running 87 octane).
What should I start with in order to improve mileage? All the maintenance has been kept up on this truck. It has been 27k since the fuel filter was changed. The truck is stock, 5.3L, stock 16 in wheels/tires.
The truck has a 4.10 rear end, I don't tow much (maybe once or twice a year). Would it be worth it to swap out the rear end to a 3.73 or a 3.42?
I have heard about getting a PCM tune, how much do these really help?
What about upgrading the intake and/or exhaust? Worth it?
Which one of the above should I do first?
No I haven't been hot-rodding it any more than I hot-rodded my Blazer. I'd like to investigate the above and leave my driving habits alone.
Thanks,
Bryce
Hello:
Thanks,
Bryce
First off, remember your Sub weighs a lot more than your Blazer and tips the scales at close to 3 tons and has an extra 2 cylinders to feed.
Having said that a gear change would help but not a lot. I have 373 in my Tahoe and I get 12-14mpg around town and it's a little lighter than your Sub. If you have 4x4, I doubt the increase in mileage would offset the cost of the gear change.
An intake and exhaust combo should net 1-2 MPG as it did on mine but then I tend to get "into" it a lot more 'cause it's more fun now and that offsets any mileage improvement. A custom tune may help but again, if you romp on it more, no gain.
Bottom line IMO driving style and speed has more impact on mileage than these changes. I can get 4-5 more MPG on highway by driving 65 instead of 85 :) I say get over it, it's a tank.
Hi:
Perhaps I should have added this disclaimer: I know that the Suburban is big, heavy, and uses a lot of gas. I did not buy it to be a fuel efficient vehicle. I will not sell it because it gets poor gas mileage.
On the other hand, if I can get better gas mileage and still drive the Suburban then there is no reason for me not to do it. I asked the question because my suburban seems to be getting lower fuel mileage than what other people have posted. It seems that most suburbans got about what my blazer did, if not slightly better.
Thanks,
Bryce
I'd make sure your O2 sensors are good and maybe check spark plugs/wires and check the stock air filter (or pickup an aftermarket :) ) and possibly consider an exhaust system. But I'd only expect 1-2 mpg increase like Bish said above. Just my $0.02.
I got a decent MPG increase from a new tune. About 2 mpg. Most people I have seen on here get a 1-3 mpg increase with a mail order tune.
I did the math on mine similar to the below calc.
20,000 miles @ 11 mpg = 1818 gallons - $3,636.36 @ $2 gallon
20,000 miles @ 13 mpg = 1538 gallons - $3,076.92 @ $2 gallon
in 20,000 miles in this scenario it is $559.44 savings. So if you plan on putting some miles on it I feel the tune pays for itself. Oh and it runs MUCH better than stock.
I'm very happy with my westers tune. The best investment I have made for my Tahoe.
Stock 2001 Suburban with 5.3L @ 11MPG
That's more like a Sub with an 8.1L.
It's supposed to be average rated 14-18MPG with a 5.3L
Something is wrong.
27K for fuel filter is much too long. Most here go max at 15K, some here change at 6-10K.
First do's that put you in a very good start point.
1. Check all hoses, especially vacuum, for cracks/leaks.
2. Check ECM for any codes that have been thrown.
3. Decarbonize the engine.
4. Change all fluids and filters. Wait for this after #3 as the oil gets contaminated from the process.
5. Change plugs and wires.
At least for myself, those would be things I would do on any pre-own vehicle I've acquired.
The fact that you got 12 MPG in your Blazer tells me it is your driving style.
Ease up on that throttle and you'll get better mileage.
I would have to say easier on the throttle, and maybe trips longer than 1 mile and you will see an increase. My 'Burb get 13-14 in town, and most of my trips are 4 miles/10 minutes (between work and home). Now, I have the FFV 5.3l, but I doubt that makes much difference. I could also go easier on the throttle, but I won't, LOL...
Most of you will probably think this is a dumb question...so I apologize to you in advance...since I dont know much about this, I am going to use it as a resource. What is this "Westin" "Custom Tuning" all about? Any information would be helpful. Thanks.
Gear ratio is hurting you
I have a Yukon with the 5.3 & 3.73 ratio I get 13.3 mpg city driving
I just got a tuned PCM from Wait4Me Performance for $ 150.00 If I can get the 1 -3 MPG improvement others are seeing, I figure that 2 MPG would be a AVG of what others are seeing, Then the $ 150.00 investment in a PCM will pay for itself in about 7,000 miles based on current gas prices.
If you want to maximize your fuel millage and performance in crease is not really what you want then specify a pure millage increase PCM re-tune. you will defently get better milage than you are getting now.
we are pushing 5,000 lbs plus hard to get great gas millage, but every little bit helps.
A couple of other things:
1. Check your air filter. By using a K&N drop in you should pick up a mile or 2 per gallon.
2. Engin oil. Switch over to 5W30 Full synthetic. This is usually good for a mile or 2 again.
Might not conside these as mods but rather routine maintenance. They can and do make a difference. You did not state how many miles you have on it. Might be time for new plugs and an upper intake cleaning also.
Not knowing the terrain you drive, it is impossible to tell if a gear change would be worth it. If you live in a flat area and have no hills to climb, then agear change will help. In my area with all the hills, a taller gear will help fuel milage, as the engine doesn't have to work as hard.
Check your tire pressure, filters and unload anything you don't need to carry with you.
I have just returned from a 230 mile round trip to the mountains (for
fishing but didn't catch anything worth keeping, but that's another story)
after installing the "new" computer with a Wester's custom tune last night. My
power was phenomenal going up hill, the Tahoe just kept pulling. Great
throttle response. Cruised at between 65-75mph from 7000-9500 feet in
altitude; Blew past a ricer at 85mph going up Trout Creek Pass, had loads of power to pass and to top it off, I averaged 18.1 MPG for the trip which included stop-n-go in town!!!
I'm sold on a Wester's Tune.
    needafix
    needafix
  • Who's Online   6 Members, 0 Anonymous, 595 Guests (See full list)
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
