Rough ride at high speeds
I recently went on a camping trip. It was quite a distance on open roads so I was doing 80MPH +. I began to notice that at about 75MPH the whole truck rocks like I'm on a bumpy road - the passenger seat shook side to side and the back seat shook forward and backward making an AWFUL rattling sound. It seemed to do it for 30 seconds, then not for 30 seconds, then do it, then not, . . . But once I got to 80+ things smoothed out considerably. Any ideas?
I was thinking tire alignment or balancing (because I've never done it), but I would think it wouldn't be so off and on though.
You were probably feeling all of those Honda Civics you were driving over. :crackup:
I'd start with getting a balance done on the tires and go from there. Good luck.
Yep, definitely start with the wheel balance. Had a similar experience not long ago.
If it's shaking that bad at very specific speeds...It could be ujoints...Or it's that wheelbase/road oscillation/frequency thing I bet. My truck will shake the fillings out of my teeth for a 2 mile section of highway between work and home if I hit it between 68 and 73 mph. Anything above or below that and it's smooth-sailing. It's got something to do with the way the road was laid, and the wheelbase on our trucks. I've been in other peoples trucks (same as mine) on the same stretches, and they all do the same thing for the same stretches of highway.
I'm going to get the tires balanced when I get a chance. It did it over a stretch of about 150 miles, several different roads/freeways. . .that kinda makes me think it's not roadway, but I don't know.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
