BigWheelinBubba Posted August 4, 2005 Posted August 4, 2005 Has 245/75/16's.. the label on the inside of the door is gone Tires look a little low/uneven just wondering where to start. Thanks in advance.
Ape0r Posted August 4, 2005 Posted August 4, 2005 If it has LT tires with max pressure of 80, 60 front/80 rear is pretty common. If the truck has P-rated tires with max pressure of 44 (though no HD truck should!), pump them up to the max.
BigWheelinBubba Posted August 4, 2005 Author Posted August 4, 2005 If it has LT tires with max pressure of 80, 60 front/80 rear is pretty common. If the truck has P-rated tires with max pressure of 44 (though no HD truck should!), pump them up to the max. <{POST_SNAPBACK}> Thats what I was looking for, thanks. PS the truck has had 45 in them since i got it a few months ago.
desrtrat Posted August 7, 2005 Posted August 7, 2005 look on the side wall on the tire and it will state max psi cold. set them to that and see how it feels and ajust from there, do not go over that max
