question about changing shocks
i replaced the factory shocks with bilstein's about 4 months ago and i am getting a progressively worse vibration, expecially when i get over 60 mph. it's hard to explain but it feels like i am always driving on a gravel road. the shocks seem to absorb the rough terrain but any small hole or imperfection in the road the whole truck just shimmy's and vibrates. i have had the tires balanced and an alignment done and that didn't help. the shocks are not loose either. my only other idea could be the way i installed them. they front shocks came with 2 rubber bushings(for each) that i also installed. one on the top of the shock(below the shock mount)and the other on top of the shock mount. so they look like washers on both sides of a bolt and nut. was i not supposed to install these rubber pieces? or maybe i should have just the one on top of the mount and not the one between the shock and the mount? please give me some ideas here....thanks!
The upper shock mount uses 2 washers and 2 rubber stoppers to sandwich the mount between the rubber stops to isolate the shock from the body where vibration is concerned.
----Nut
---Washer
---Rubber bushing
---shock mount
---rubber bushing
---washer
---shock piston
Sounds like you have them installed correctly. I would suspect something else at this point. Possibly wheel bearing?? Could be a bad shock but I wouldn't think it would show up as a vibration. Wheel alignment??
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
