C3 Transmission
Does anyone know what tranny is in a C3 pickup? I have heard 4L65EHD and 4L80E> Want to make sure before I get a converter to get the right size. Thanks
I would think it is the 4L80E, but what you should do is look in the glove box at the list of RPO codes, and then compare them to the codes for the corresponding year from the list of RPO codes that you see in the left hand column on this page under the "Features" section.  For example if your truck is a 2001 and the code MT1 is in the glovebox, then you have the 4L80E tranny.
Hope this helps...
I thought (i could be wrong) that the C3 had that new 4L85E tranny?
Then you should have a RPO code of MN8.  Here we go again with the great mystery question...  What actually is the difference between the RPO's MN8 and MT1.  Both are shown as a 4L80E...
Our trucks have the 4L60 E-HD transmission in them. I think the 2002 Sierra Denalil has the 4L80 due to the lower rear end ratio 4.10 and the increased trailering capacity - 10000lbs. Hope this helps.
I looked it up today, it had M32 which list as a 4L60E with Tow Haul. thanks for the help everyone. Now I wonder which converter I should get......    :D
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
