What do you guys suggest for bulbs
i was driving the other night and really noticed the stock lights leave something to be desired, im thinking about picking up some of those projectors like on ebay but hear about all the 9005 sockets and 9006 sockets the yukon has... but my question is has anyone tried any aftermarket 9005/9006 replacements that are better? I was thinking of picking up a set off ebay but nearly all of them are for HIDs, but they don't tell you :dupe: im mainly just looking for a brighter whiter, maybe bluer light
I've been running the Sylvania Silverstars for about 4 years now and I like the improvement. Brighter whiter light over stock. One downside is the bulbs only last a year or two and they are not cheap. Sometimes I find them 2 for 1 at Pep boys.
:dupe: Hi I have the silver stars also and they have lasted me 3 yrs so far and I have ordered an new 2006 1500 silverado and this truck i am putting in a 5000K HID Xenon conversion kit from Philips I seen them on ebay 300 US but worth every penny if I get more late night light for driving . You might want to investigate this option they last a long time and run on 35w instead of 55w . and no filiment to burn out . thats my 2 cents worth hope it helps
I'm using PIAA's in my 02 Burban and have had them for 3 years with no problem at all. They definitely make a big difference over the stockers. :mad:
I would second the vote for the Sylvania Silverstars. They made a huge difference over the stock bulbs. Normally about $20 each but well worth it if you do alot of night driving.
My wife's Lexus has true HID lights. With as close as my Silverstars are to her lights I cannot justify the cost of upgrading my truck to true HID.
sweet, i think ill get the silverstars, but im thinking about also getting those black halo projector lights and converting to the 9005 sockets and bulbs and see if i can hook up the halos to the fog lights, at the same time getting the black clear corners with amber drl's or something like that... gotta save up for that though.. the trucks going into the shop for exhaust once the tips come in.. thanks for the info guys, :dupe:
  • 5 weeks later...
sweet, i think ill get the silverstars, but im thinking about also getting those black halo projector lights and converting to the 9005 sockets and bulbs and see if i can hook up the halos to the fog lights, at the same time getting the black clear corners with amber drl's or something like that... gotta save up for that though.. the trucks going into the shop for exhaust once the tips come in.. thanks for the info guys, :fume:
Advance Autoparts has a buy 1, get 1 for 50% off plus a $5 mail in rebate. You'd save $15. Here's the rebate form and offer info: http://advanceautoparts.rebatestatus.com/d...v2g72owUKkkePw=
I'm presently running 9011 and 9012 bulbs. Oddball looking things, they're said to be made for euro BMW's and such and are rather hard to find(found mine on eBay). They are stock wattage but are rated at twice the lumens as stock. While they are not as white a light as Silverstars I haven't had any burned wires or sockets like the high watt bulbs can sometimes cause. And they claim they will last every bit as long as a stock bulb(I got almost 8 years on a couple of those!)
They do seem to reach out a lot farther than the stock ones AND the Silverstars.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
