I'm looking at a 2002 Envoy SLE 4 door 4WD with 24000 miles on it. Is there anything I should be looking for on this vehicle? Any known problems?
2002 was first year for the new style Envoys. The 2002's had some engine problems with cylinder wall failure on early production units. Remedy was to replace the engine. The front stabilizer bushings often require replacement, as do the front and rear stabilizer bar links.]
The 2003 and newer are more reliable. If yours checks out okay, I would think a purchase price of under 15K would be worth a consideration.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
