6th seat for my AV
I have an AV with the center console so I can only seat 5 folks.  I have seen these center console's that can covert to a seat.
Does anybody know if they make one I could use in my Av?
I bet someone here would love to swap you the split bench for the buckets with center console!!!  With the split bench you still get the look and feel of buckets when you want and then when you flip up the big armrest you can seat 3 upfront.
The interior is grey.  But what you said about it being annoying makes me VERY leary.
Why do you not like it?
BTW: Just to be clear, I am only looking to replace the center console, not get rid of my big comfey heated, 6-way power adjustable, with two person memory, front buckets  :)
Hey Empty
Yes, the ducts run under the console, however the vents are in the console so by loosing the console, you would just nuke the rear heat system.
I don't know of any aftermarket "console replacement" middle seat that would retain the original seats.  One of the other guys above can tell you what the GM OEM Bench/Console seat has for options.
Scott
I did the opposite of you, you can swap anyone w/ the same interior.  Just make sure you either get the cover plate or cupholders (depending on there year) that go into the dash where your console goes into the dash.  But, it shouldn't be much of a problem.  You can check out my site if you want some more info or pics.
    ceeemcgeee
    ceeemcgeee
  • Who's Online   3 Members, 0 Anonymous, 780 Guests (See full list)
