F/S PIE GM9-AUX
Black-Z71
Brand new never used aux input converter. I ordered this for my father's Blazer, but it turns out it won't work on his truck. I paid $70 for it last week...I'm looking for $60 plus shipping. See the applications list below...be sure this will work on your vehicle before sale. I can't guarantee that it will work on every vehicle. Thanks.
Chevrolet
# 1998-2004 Astro Van
# 1996-2002 Avalanche (For 2003-2005, see GM12-AUX)
# 1997-2002 Blazer (For 2003-2005, see GM12-AUX)
# 1997-2002 Camaro - Radio must be AM/FM/Cassette w/"TAPE/AUX" button
# 1995-1999 Cavalier
# 1996-1997 Impala (For 2003-2005, see GM12-AUX)
# 1997-1999 Lumina (For 2000-2005, see GM12-AUX)
# 1996-2000 Malibu (For 2001-2003, see GM12-AUX; not compatible w/2004)
# 1995-1999 Monte Carlo (For 2000-2005, see GM12-AUX)
# 1999-2002 C/K Truck (For 2003-2005, see GM12-AUX)
# 1995-2002 S10 Truck
# 1998-2002 Silverado (For 2003-2005, see GM12-AUX)
# 1995-2002 Suburban (For 2003-2005, see GM12-AUX)
# 1997-2002 Tahoe (For 2003-2005, see GM12-AUX)
# 1997-1999 Venture (For 2001-2005, see GM12-AUX))
GMC
# 1999-2001 Envoy (For 2002-2005, see GM12-AUX)
# 1998-2002 Jimmy (For 2003-2005, see GM12-AUX)
# 1998-2002 Sonoma (For 2003-2005, see GM12-AUX)
# 1996-2004 Safari
# 1995-2002 Sierra (For 2003-2005, see GM12-AUX)
# 1995-2002 Yukon (including Denali) (For 2003-2005, see GM12-AUX)
IMPORTANT APPLICATION NOTES:
1. The GM9-AUX is NOT compatible with vehicles equipped with 6-disc in-dash CD changers.
2. 1995-1999 GM radios are not capable of controling the GM9-AUX Input Converter when a factory non-dash mounted device (such as a single disc CD player, or cassette deck) is present.
3. 1995 thru 1999 AM/FM/CD radios are NOT CD changer capable, and will not work with the GM9-AUX.
4. 1995-2002 AM-FM-Cassette radios WILL work with the GM9-AUX but will require any slave unit, if present, to be disconnected.
  • 7 months later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
