2006 duramax
jake_33
iw as just lookin at the 06 duramaxs witch have 360 horse and 650 torque and iw a sjust wondering how well would a 05 put up agianst it
As far as what? Towing? The LBZ is so new that the verdict is still out on how it does in the real world. On paper, and from the mouth of owners of new LBZs - it appears to be a beast. :shakehead:
  • 4 weeks later...
As far as what? Towing? The LBZ is so new that the verdict is still out on how it does in the real world. On paper, and from the mouth of owners of new LBZs - it appears to be a beast. :D
I JUST WENT FROM 05 TO 06 DURAMAXHP, IT IS A BEAST ALRIGHT. UNBELIEVEABLE & THE 6 SPEED TRANS IS B.A. :P
  • 1 month later...
After driving both 05 and 06 I can tell you there is a whole world of diff. and the 06 is far better and much quieter. trans is a lot more responsive in haul mode than 05. :banghead::D sure would like to compare 07 if they add a litte extra like i think there going to..
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
