Computer problem
Black02Silverado
Been having an issue with my computer. It is one I built, has a Gigabyte mother board, with a 2.4 Pentium 4 processor, I have 1 gig of memory from Crucial Memory in it. Here lately it has just been shutting down on it's own. I mean bamm it is off, no warning, nothing. It did it when I had Windows 2k on it, so I figure time to upgrade. I reformated the hard drive and installed Windows XP Pro. It is still doing the same thing. It will run for days and then do it again. Or like today I came home from work and it was off so I started it and with in maybe 10 minutes it shut down again. I opened it up and blew it out a while back as well, it was kind of dusty inside but not to bad.
Any suggestions as to were to look next? :cheers:
A slight adjustment with a tire iron should do it :crazy::smash::smash:
I have had similar problems that you just can't put a pattern with.
It almost sounds like it has to be power supply related.
The software and therefore and percieved virus cannot be at fault.
If you have a spare power supply, swap it out and then maybe recheck all pin connectors on the MB.
Good luck with it.
We had the same problem here at work on a few machines. In all cases the power supplies were faulty. I would change out the power supply as they are pretty cheap to begin with.
I installed Speedfan and my system is running at 25C. According to the gigabyte mother board book it doesn't get to an over temp problem untill 50C. I'll leaning towards a faulty power supply.
Thanks for all the help. :flag:
  • 4 weeks later...
Just wanted to thank everyone again for all their help. I found the source of my sporadic shut downs. It was my Fellows battery back up. It is gone and APC is replacing it.
Thanks again everyone. :D
