PS Pump Pulley
GMC Rider
Search was down, sorry if this has been asked before.
I recently bought a 2000 Sierra K1500 Z71 5.3L, and it has started a gawd-awful belt chirping mostly during cold starts. The noise dies down after the engine has warmed up, and sometimes I don't hear anything at all.
I am replacing the belt and tensioner this weekend, but I have heard that the PS pump pulley can move off it's position on the shaft and cause the same thing. Can you tell me how the pulley should be aligned with the shaft (flush or measured offset)? The truck has 116,000 miles.
Thanks :D
The hub part of the pulley is *supposed* to be flush with the end of the pump shaft; however, that's not always the ideal position.
I don't believe the pulley can walk to a different position on its own. That sucker is on there pretty tight.
P.S. pulleys have been our biggest problem when it comes to the type of belt noise you're talking about. If the pulley is not flush, make it so, if it is flush, you may have to move it in or out a bit. A "bit" is defined as about 3 mm at a time.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
