Coolant Leak
Zippy1234
I have a small coolant leak originating from a small plug (~0.5 inches in diameter) in the engine block on the driver side next to the power steering pump on my 2001 Suburban. :D The plug has never been removed and the engine has ~ 60K? Just changed the coolant at ~ 55K with 50/50 mix of Havolin Dex-Cool and distilled water.
Does anyone know if GM uses a "stop leak" with the factory fill?
They do on some vehicles. I have not heard that being the case on the trucks, and I doubt that they do. The residue from the type of stuff they use always ends up in the recovery tank, and I've never seen that residue on a truck.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
