cruise quit update
:cheers:
all is working just fine now.
Turns out both rear brake lights were burned out.
Replaced them last night and had a chance to try out the cruise earlier this morning.
One fellow from Colorado posted he had the same problem.
Who would have thunk such a thing and I saw nothing in the manual about it.
Anyway if your cruise all of a sudden stops working, check your brake lights.
This board is great, thanks.
Your rear brake lights could have burned out because the brake switch is sticking. You may want to look at the switch too.
If you brake switch is sticking you wont have cruise. Touching the brake disables the cruise. Riding the brake peddle keeps the cruise from engaging and renders ABS almost useless since brake switch activates ABS process.
