Nav #
What does LUX or Non LUX indicate?
Lux and non lux generally refer to which Bose amp you have in your vehicle. One way to find out is to look in your glove box at the RPO codes listed on the sticker. If you have Y91 as one of the codes you are likely to have the Bose lux amp (although, not always a guarantee). If you don't have the Y91 code you probably have the premium Bose amp. If you have the center console in your truck, the amp is located within the console, mounted to the floor bracket.
