5.7 Codes/Errors
So my company truck wouldn't start yesterday morning (nice and rainy and cold outside to)
The battery was fully charged, it would crank and crank like it wasn't getting any fuel
Wouldn't start on Ether...
Replaced the sensor down in the distributor cap because it did that once before, and replaced the censor on the passender side of the intake.
Truck still wouldn't start
Scanned the truck for codes just for the heck of it and found P0420 and P0430 ( catalyst-efficiency-below-threshold) and P1345 (this one bugs me the most) (CKP/CMP Correlation)
So I cleared the codes, and the truck still wouldn't start
So I take the fuel pump relay out of our other company truck and the truck started, and the tool truck started on the relay out of my truck.. :pissed:
So today the truck still starts alright except now the truck will sputter around 45-55mph when giving it gas.. so I checked the codes this evening and got P0420 again so I cleared it again.
I take my time and make it to night class (where I sit here right now lol) and I check the codes again and this time the P430 and P1345 pop back up.. :pissed:
I have no clue where to go from here (except new 02 sensors for the P420/30 codes)
I guess 300K has finally caught up to the motor.
Larry the mileage has caught up to your distributor's phasing. Since you no longer set the timing at the distributor what you do is align the cam sensor when you turn the base. It's built to have the rotor and cap matching when the cam sensor in the base is lined up to the crankshaft correctly. Well after many miles of gear wear and timing chain strech the rotor tip no longer lines up with the cap terminals when the crank is in the right place and you get some misfireing during periods of maximum spark advance as the spark misses the proper plug terminal or doesn't have time to fully make the correct terminal in the cap as it goes by with max advance. What you need to do is find someone or a shop that has a professional grade scanner such as Snap-On or OTC Genesis that can read the CAM RETARD field and readjust the distributor until it reads 0* (+/- 3*). This often requires enlongating the bolt hole in the distributor hold down clamp into a slot so you can crank it further than what the factory provided for a fresh engine. This will eliminate the sputter (misfiring) and make the truck run good again.
The bad news is that the misfireing has likely done the convertors in and they are now either partially clogged from melting or just not cleaning enough anymore. When the fuel doesn't burn in the cylinder it gets into the exhaust and often burns in the convertor. This ruins them pretty quickly. If you're in an area that requires you to pass an emissions test to get a new inspection sticker then your SOL until you get the misfiring fixed and then have the convertors replaced. A good tune up will ensure the new convertors will last.
Turning the distributor correctly will take care of the P01345 and fresh convertors would do the P0430. The 1345 is important for engine health and the 430 is more for eviromental health, so choose how important they are to you based on that.
Good luck,
Vernon
Dealership fixed it today
Distributor Gear worn, housing cracked - new distributor
New egr valve
New air filter (needed one anyways)
and new o2 sensors
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 921 Guests (See full list)
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
