2000 Tahoe wont turn over
never had a problem with it, but i noticed the security light came on the day before while driving. it went off when i turned the car off then back on.
well.... i go out to start it today. i have about 10 volts on the battery meter, but the starter wont crank.
anybody have any idea what it could be?
45,000 miles on it
thanks!
45,000 miles on it
thanks!
Sounds like it's probably time for a battery. Start there, check all battery connections, make sure they are tight, with no corrosion.
45,000 miles on it
thanks!
i put a brand new battery in it 2 months ago. die hard gold. :rolleyes:
45,000 miles on it
thanks!
Something may have ran it down, or could be a bad battery. Should definately be under warranty.
[something may have ran it down, or could be a bad battery.  Should definately be under warranty.
the starter wont even turn if i try jumping off another car.
the warrenty is only 3 years i believe
thanks for the suggestions though
No, I was talking about warrenty on the battery, if that turns out to be the problem, since it's a new battery. Sorry.
I have had the same type of problem. Went through 2 Die Hard's in 4 months. I'm positive it wasn't the battery causing the problem.
I had some sort of parasitic drain. Never found out what happened, but i was sure to make sure my battery connection was good. Make sure you use dielectric grease for the connections.
was it dead overnight? or was the truck sitting for a few days?
the car was sitting a couple days.
the thing that seems weird is the security light came on and then went off after i restarted a few days before this fiasco
all lights & accessories work fine. i checked all the fuses
i noticed on the internet it says there was a problem with the ignition switch in 2000's. and that would be tied into the csecurity system :dupe:
just tried removing the starter to test it... but they make it so hard to pull out... this is starting to become a pain
i just tested the terminals at the starter. one is hot and the other doesnt get any juice in the key start position... so this really points to the ignition switch :dupe:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
