1987 twin saddle tanks
Hey fellows, i had posted this over on the Classic Truck section and didnt get any bites. Hope it is ok i post it here....
Howdy gang. Well, i think the Maine winters are slowly starting to catch up to my 87 K20. My passenger gas tank is leaking fuel. Have a nice black stain in the asphalt out in the parking lot. Filled up that tank last week (driving on the drivers tank), noticed the puddle this morning, looked at the gauge and was down to an 1/8th.
I have seen prices for the 20 gallon (steel tank...will rust again eventually) anywhere between $90-140 from internet sites (spectra premium is a good place) to local parts stores. Auto zone wants $140. All of these tanks come with a new lock ring and o ring.
What about the polyurathane tanks? Same dimensions. Same 20 gallons. Never will rust. Wont accumulate condensation. They are slightly more expensive but seem to be worth it.
Any pros and cons or suggestions?
Also. The sending unit. Not sure if i need a new one (pricey, well over $200). The gauge works fine, the diverter valve (to switch tanks) works fine and the fuel pump runs fine. How do i determine if i need a new one or not?
Definately getting two new straps to go with the purchase.
Just wanted to see what you all had to say.
Truck is an 87 K20 with the 350 TBI, 4x4 and 4.10s with the TH400
Thanks.
Lee
I would just replace the rusty tanks with polyurethane tanks and call it good. At the very minimum you may want to change the fuel pumps since you’ll have the tanks down. I see no reason to change the entire sending units.
The polyurethane tanks work well in areas like yours where road salt is used. Chrysler has been using polyurethane tanks for years with great success.
Do you really think you're going to keep your truck more than another 18 years? Otherwise I'd just install as close to original as possible. Steel tanks.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
