ac/heat
dougss396
I know this is for trucks, but I have a 99 Gran Prix (3800) GT
With the air on the drivers side blows cold, but the passenger side blows hot. Passenger side (dual Zone) temp. selection shows its working but only blows hot air. Any suggestions>
You might want to try disconnecting the battery again to force the a/c to do a door position relearn. You may have to do this several times until the doors go into the position the a/c control wants to see.
  • 3 months later...
I have this same problem on my 04 Suburban with dual climate control and recently had a dead battery. Driver side cold and passenger side blowing hot air. I've tried disconnecting the battery about 6 times and once it reversed my problem and another time made both sides blow hot. Any suggestions? Like before shutting the a/c down should I have that temp controls set a certain way? I noticed that after leaving battery off for minimum 10 minutes the a/c control always return to 74 degrees.
The temp control goes up and down on the driver side fine but the passenger side blows hot and fan seems to slow down when set at 90 degrees on passenger side but turning down temp on passenger makes the fan blow faster.
Thanks for your help.
Jerry
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 515 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
