Z82 Option
My 03 Sierra Z71 apparently is equipped with the Z82 Trailer Equipment package (I'd checked the glovebox sticker with the RPO codes and it states Z82). I've purchased this truck (used vehicle) a week ago.
My question to any owner who purchased a Z71 brand new from the dealer that is equipped with the Z82 option - was anything else supplied to you at time of delivery (ie wire harnesses, trailer balls, etc)?
Thanks
Thanks
I think the 7-way plug adapter and the harness for the brake controller.
Receiver Hitch
7-way bargman plug Pre-wired for electric braker controller & 12volt battery charge wire
Heavy duty cooling
External air to oil transmission cooler
Power steering air to oil external cooler
3.73 or 4.10 gear ratio
full size spare tire
High flow heavy duty paper element air cleaner
And suppose to include a "pig-tail" for you to connect your electric brake controller to the factory plug in the plastic box just above your left foot driver side under dash. and a fuse to replace the dummy fuse under the hood.
Those are the normal add added items on a tow Pkg & what was on my z82 Yukon
I got a brake controller pig tail with my truck as well. Looks like a useless thing because they did not provide an electric brake controller itself. Is this pigtail used to connect the brake controller to the vehicle electrical system? If so, where does it plug in?
The tow package came with the 7 pin plug mounted on a crookedly welded bracket. :rant: Of course, GM was too cheap to provide a 7 pin to 4 pin flat plug adapter.
Yes,It is used for an electric brake controller.
It plugs in under the dash,On the drivers side right by your E-Brake pedal,Theres a black plastic cover over the "Bussed-Electrical-Center" pull that cover off and theres a decal on the underside that shows you where it goes.
