Gas milage went to heck--cant figure out why?
I have a 1500 chevrolet extended cab 4x4 truck with the 5.3 engine. These are my mods.
Airaid induction
series 50 suv flowmaster exhaust
waitformeperformance chip
I was getting between 17-19.5 mpg on the highway.
I was getting 15.5 in city driving.
I got this for the first 5 months.
Now i have not traveled so i dont know highway mileage but i am getting only 13.5 mpg in city driving. I am easy on the gas as i can be and have not done anything different that i can think of except 1 thing. I got my first oil change and went with mobile 1 total synthetic oil. Im not sure if that alone would do it. I did for one tank put in Marvel Mystery oil additive to my fuel and I lost 3/4 of a mpg for one full tank of gas which led me to think mabey my oil change was the culprit. And by the way I have had no power loss or anything weird happen and i check every single tank of gas i run thru for milage.
Also I did a crankcase relearn but that was about a month before the gas problem was noticed. I did this because of the chip from wait for me caused a problem with my check engine light and i was told to do a crankcase relearn. Im not sure if this could of been the problem.
So i went from what i thought was good gas mileage to crap and i cant figure out why. Any suggestions would help--mabey the programming is corrupted or something in the chip or mabey you guys have seen something similar and have and answer.
All I can suggest is that you reinstall the original PCM with the factory programming and go from there.
I am not sure where you are at but winter blend gas will kill MPG by 2.
In Michigan gas stations run it from Roughly November until April.
I always can tell when I get my first tank of summer blend and I gain nearly 50-60 miles per tank full.
I am running a W4M tune and have a 1500 5.3, 3.73 EXT,4x4 with and live in MI and my average city is 17.5. Must be your O2 sensors are gone. BTW i use Mobil 1 in engine and axles other than that and a tonneau its pure OEM.
I didnt think of my 02 sensor. Dont know why it would go to crap but that might be it. Would my check engine light go for that though. Also i read on these forums once that your mass air flow sensor can get dirty and go bad and kill mpg--is that a possibility?
Is this a 2005 (as I'm assuming from your user information to the left)? If so, I'd doubt the O2 sensors would be going south that soon - unless you have a hell of a lot of mileage already. Unless it fails entirely, they don't set a code as they age, they just get slower to react. I just replaced mine this morning, so we'll see if my MPG goes up.
Since you post that you have an Airaid intake, I would look at the MAF as you already were thinking. The filter could have been over oiled, which may now be coating the sensor wires of the MAF. For the cost of a can of electronics cleaner (I got mine at Home Despot in the electrical section) and a few minutes time, you can give yours a blast just before your next fillup. If it doesn't solve the problem, have a dealer check it out for any codes that are set but don't light up the SES indicator. As long as it's under warranty, try to make the most of it.
Good point, I use a oil wetted filter and you do need to clean the MAF often. Brake clean and a cotton swab will do it. Clean the Z wire behind the MAF grate. Just cleaning the grate will not do much. Just be gentle on the Z wire with the swab. Does not take much to clean it.
I would still be curious if your drop in MPG lines up with winter blend gas in Michigan. When did you notice the big drop in gas mileage. It will also be interesting come mid April if it all of a sudden comes back to the mileage you had before.
Do not under estimate the MPG loss of winter gas. You get less BTU's per gallon but you won't get frozen fuel lines.
On 1996 and newer vehicles, if an O2 sensor gors bad or need repalcement it will throw a code unlike the older ones that need periodic replacement at higher mileage.
I would clean the MAF and re-install the stock air filter, go back to stock PCM programming. As for the exhaust, ensure that it is of the same diameter and spec as the stock system as anything bigger will change the backpressure and cause problems.
Also, do ensure you only use "tier 3" gas, you can check websites for this, Chevron and Shell are among the few who refine to this spec. GM highly recomends that only tier 3 gas be used due to its higher detergent concentrations. Maybe your injectors are getting clogged.
OBD2 will NOT set a code for lazy O2 sensors which cause poor fuel economy only when they get out of the parameters that the PCM is looking for.
I have given up on trying to get better mpg. Truck is always serviced, you name it and it's been done maintenance wise. When the gas started going up because of Katrina, I really made an effort to accelerate mildly, try to watch for lights about to change, blah blah. Still I get only 13-15 TOPS!. Ihave realised a full size truck with 4wd is what it is, so now screw it, I drive how I want. It is not worth driving like you are carrying nitroglycerine in the bed for a lousy 1 MPG increase.
Figure it out 1 mpg at 100000mi just at $2.60 a gallon is almost $1100 and gas is going to get up over $3 probably $3.50 or more this summer thay say. So its quite a savings.
I started to notice the drop in beginning of November. The same time i did my synthetic oil change.
Real quick question---is getting to the MAF easy and how would i get to it.
MAF is right on the outlet of the A/C housing just unscrew the clamps and carefully remove it and clean it with electronic contact cleaner.
Tier 3 gas???? what is that?
all gas comes from the same distibutor. There are only 1 or 2 distributors in all of NY state. when the tankers roll in, they throw some additives in the tanker, and wha-la, branded gas.
    • Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • On my wife's 2020 Blazer (~69000 miles), we started to notice the brakes pulsating at faster speeds. Typically around town you don't notice anything, but highway/interstate driving you will notice it. I decided to pull of the front tires and look at the brakes. I figured with the milage, the pads should be wearing out to their life span, but they actually looked decent. Still with "meat" on them. One pad has a ridge wearing in it, and that same rotor is showing the ridge too. That's not the concerning part...the other rotor appears to have a raised bump on it!  The picture make it look like a pimple! Very odd and strange! NOTE: These are the factory brakes and rotors.   I'm attaching pictures of the front brakes and what they look like ate ~69000 miles.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
