Silverado?
Gentlemen,
What , exactly, is the difference between a
Silverado and a C-1500? Mine has been de-badged and I honestly don't know what I own.
Ken
Up until 1999 GM trucks were designated as C series (2wd) or K series (4wd). Over the years there were different trim levels. I remember the Custom Deluxe, Scotsdale, Cheyene, and ultimately the Silverado was the highest level trim in the Chevy truck line. As the Lariat is the highest trim level in the F-150 series from Ford. However with the 1999 model year GM renamed their truck series Silverado. Silverado was the name for the entire line. So if you have a 98 or prior truck it is considered a C or K.
vroten :cheers:
From what I see in your profile you own a 2000. So, it is definitely a Silverado. It also says 1500 so you know what GVWR you have too. The only question now is is it a WT, LS, LT2, or LT1. Those are the option levels that replaced the various names like Cheyenne, Silverado, etc. that were mentioned before. This can probably be determined by the SPID stickers in your glove box.
I didn't know there were two "LT" levels in that year, I thought that started recently with the tiered "LT"'s. I thought back then it was just "WT" "LS" "LT"...
Learn something new everyday. What was different between "LT1" and "LT2" then?
Gentlemen,
It is 2 wd and a very high trim level, consoles, great seating extended cab a very nice truck. When I go to auto zone they list c 1500 and silverado separately. I always assumed that because of the very nice interior it is a Silvy.
I love the vehicle but am curious what the heck it is. It has the 3.73 gears and jumps like a scared rabbit. Glad I got rid of my Ford. Last seen smoking from every orifice on I 10 in Blythe.
Ken
In 2000 they had both the Old-Body Style "C/K" model and New-Body Style "Silverado" model,However in 2000 all the "C/K's" were Heavy-Duty 2500's,3500's and 3500HD's,The Silverado's were either 1500's or Light-Duty 2500's.
In 2000 they had three trim levels for the Silverado Model:Base,LS and LT.
The LT1-LT2-LT3 didn't start until this year ('06)
The C/K Model Pickups for 2000 had two trim levels:Base and LS.
If you have a 2000 1500 it has to be the "New-Body Style" Silverado model because all the 1500's in 2000 were the "New-Body-Style" trucks.
(In '99 they had both the "New-Body-Style" and the "Old-body-Style" 1500's)
AutoZone asks you what model you have because both were available that year and very few,if any,parts are interchangeable between the two.
Working in the parts department at a GM dealer I go through this myself all the time,When I ask the person what model they have most of the time they don't know,So I just ask for the VIN,That tells me for sure what they have.
Hopefully I didn't confuse you!!
Gentlemen,
Thank you very much. The knowledge here is impressive.
I have said this before but I have an inky black near new Acura RL in the garage that I have driven exactly twice since I got my truck three months ago. Am I crazy or do I just appreciate American Iron?
Ken
The C and K designators are still used.
C = 2 wheel drive
K = 4 wheel drive
Yes,"C/K" is still used but now only for the reason you listed,To designate 2 or 4 wheel drive.
Used to be "C/K" was the actual model name but not anymore,They refer to them as the "Silverado" or "Sierra" model.
Nope, as MS3Dale stated below, I am the one who is learning. I stand corrected. I just made the assumption that there was multiple LT levels back then as there is now. Just like GM, always trying to confuse me. lol.
    • There are knowns and unknowns.   Knowns:   - LT, RST and LTZ names/trims are gone.  The new "Silverado" trim level replaces all 3 of those.  You should be able to configure the Silverado trim to match the equipment levels of those three trims.    Unknowns:    - Custom.  No mention of what engines it will have access to.  Dual exhaust being standard does seem to confirm a V8 option for the Custom trim though.  My "guess" is that Custom will have access to the Turbomax and the 5.7.  I could be wrong though.  The current Custom trim went 2.7 Turbomax only the last 4-5 years, and only had a single side exit exhaust.     - 40-20-40.  I would imagine that is NOT going away.  They only focused on showing the new interior on the top trims, Trail Boss, ZR2 and High Country, hence the images shown are just bucket trucks up front.         The info should start coming fairly quickly over the next weeks and months.  Production is supposed to start up later this year, so when the order guide launches, you'll be able to see the configurations of engines, cabs, seating, etc.
    • I don’t do offloading other than a dirt road literally for me it’s more about the look which I really appreciate a nice looking truck and I like sitting a higher and not just because I’m 5 foot seven lol..  I’m also not compensating for anything lol..  but I truly think it’s safer on the road the higher you sit you have better visibility generally speaking especially a few of your Sideview mirrors adjusted correctly. They do make a programmer rough country does they’re $1000 for these new 2500s but when I do a gear swap that would be a moot point. A lot of the shops that I go to in my area they’re all saying the same thing that Yukon Detroit axle Eaton Spicer Richmond they don’t have gear shot for these trucks which surprises me because hasn’t this body style been out since 2020? I’m hoping soon they have something because yeah I’ll have to spend the 3K to get both axles done. Thank you for all of your response responses. I apologize if there’s any grammatical error errors as I’m doing speech to text on my iPhone without proofreading
    • I guess I don’t look at it as extreme I had 11 inches on a 1500 ram with 38 I had a 4 inch on a OBSF350 with 37 I had a 4 inch on an OBSF 250 with 35 and I’m not really into off-road I just appreciate good-looking vehicles this truck will never be offloaded other than maybe a dirt road    I mean the factory is even putting 37 on Broncos etc. Raptors they know what people want
    • Topic: OCI, not when but why? Have you considered that just because there is limited documentation on GM's programming of the OLM system that it is not a sign of it's simplicity but a protection of intellectual property? We both agree the system's published parameters are too limited to present an accurate picture of oil quality.   I am not discussing my oil change routines in this comment, I am discussing the parameters of the GM OLM; a key component of "OCI" when and why.   You know what I find interesting? GM trucks, discussing things relevant to those trucks.   If free conversations are not allowed in threads you start I suggest having a discussion with a moderator to have them grant you authority to police and suppress the free exchange of thoughts on your topics accordingly.   Alternatively, if you only want to talk about oil without distractions I suggest bobistheoilguy.com or starting your own blog.   Carry on your discussion of "Engine Wear and ISO 4406"
    • And I was thinking of this factor as well in that if a customer does not well maintain their vehicle ( which means going by the manufactures schedule in most cases ), that vehicle in theory by the time they trade it in or sell it privately will have potentially a shorter life span on some major components as a result and so that vehicles life either cut short or a lot of parts thrown at it to keep it on the road. In either case the manufacturer wins because its either selling more parts or that vehicle has hit the grave yard and becomes a win win for the manufacturers. So indeed the salesmen love a scenario like this .. yes yes, treat that vehicle I sold you like garbage so I will be seeing you sooner then you think for your next new vehicle purchase  ! 😆   OnTheReel, I looked up my OLM percentage for the last oil change that was done with 2500 miles on it and it read 48% and that was an interval through the winter so more idle time and so on and while not scientific, when I changed the oil it had this weird color to it that I can't say I have seen before and to keep in mind that I burn dyed fuel but so does all other gas vehicles I use and I have to wonder if fuel dilution and allowing more of that dye into the oil was showing up or what but it sure didn't jump out at me as saying I was dropping the oil way too soon. Instead it made me think of what a local long time mechanic had commented on with my truck that he recommended I change the oil every 2500 miles as the number one thing to keep this engine type in good mechanical service. But again its not like that oil was sent to a lab to see where its life was at so this is only anecdotal.
