Fuel gauge problems
jakemi
Have a 2000 Z-71 with 106,000 miles on it. The gauge is starting to act up.
When its idling, the gauge makes a noise (off/on) then the gauge reads emety then shoots back up to where it should be. Is it the senser behind the display? Is it a easy fix to buy a new senser and replace it behind the display?
Thanks
Most likely it's the sender unit in the tank. You'll have to decide whether to drop the tank or raise the bed...
If you are not having any fuel pressure problems, you can just replace the fuel level sensor on the sending unit. (much cheaper). Like mike suggested, you can jack the bed up but be careful. I loosen the right bed bolts about halfway. Take the left ones out. Unbolt filler neck from bed and unhook taillight connectors and raise the left side of the bed. Be sure to put some blocks between frame and bed.
Parts Information
Parts are in limited quantities. Please DO NOT order parts for stock.
Part Number
Description
89060635
Sensor Assembly, Aux Tank, Rear
2001-2003
360364 0353, Cab/Chassis, Reg. and Ext Cab
with LQ4 or L18 and minus NQZ (with aux fuel tank)
89060636
Sensor Assembly, Main Tank, Side
2001-2003
with LQ4 or L18 and without K53 (robust fuel system)
89060637
2000-2003
159259 0636, C/K, Long Wheel Base Utility
with LM7 or LQ4 or LQ9 or L18 and without K53 (robust fuel system)
89060638
2000-2003
157 06, C/K, Short Wheel Base Utility
89060640
1999-2003
100200300 034353, C/K, 2 Dr, 4 Dr and Ext Cab Pickup
with LU3 or LR4 or LM7 or LQ4 or LQ9 or L18 and -- K53 (without robust fuel system)
2004
100 0353, C/K, 2 Dr and Ext Cab
with LU3 and without K53 (robust fuel system)
89060642
Sensor Assembly, Main Tank, Rear
2000-2003
88965384
Sensor Assembly
2004-2005
HUMMER H2
88965817
Sensor Assembly
2004-2005
Colorado / Canyon
Parts are currently available from GMSPO.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 1,160 Guests (See full list)
