carpet cleaning
Hmmm, if you mean what kind of product...I usually use Simple Green or Bissell Carpet cleaner. I use a little Hoover upholstry extractor to do my seats and carpets, works pretty well.
The best aerosol that I have found is Lestoil deodorizing rug
shampoo. This stuff takes out Coca cola, red wine wine, coffee (on a light blue carpet) although like anything else that works great, is getting difficult to find. KMart did carry it last time I purchased this product.
I mainly use just plain water.  Spray from a trigger sprayer, work it in with a soft brush and absorb as much as you can with a clean, dry cloth. Alot of the cleaners leave a residue that will attract dirt over time.   Try water first.
Tuff Stuff all the way. It takes it right out and I have never had a problem with it attracting dirt afterwords. It works well on the seats too. I use it to clean the entire inside of my truck and cars.
For the really tough stains, try Spot Shot, you can buy it a Wal-Mart. this stuff is a magic worker.
