!997 C3500 No power great idle
veprk130
I just recently encountered a problem with my truck:
1997 C3500 CrewCab dually 7.4 vortec
One day is was running then the next it was not.
Engine has a hard start on cold, but when warm it idles evenly at 1000rpm.
Once I push the gas pedal it just bogs down with no power at all.
Here are the codes I found:
P0131 - O2 Sensor Circuit Low Voltage (bank 1 sensor 1)
P0150 - O2 Sensor Circuit Malfunction (bank 2 sensor 1)
P0151 - O2 Sensor Circuit Low Voltage (bank 2 sensor 1)
P0171 - System Too Lean (bank 1)
P0174 - System Too Lean (bank 2)
Any ideas would help. I was thinking replacing the 2 from O2 sensors.
Ruben
Well thanks for the tip, but it did not work.
I replaced the following:
TPS - was broken
MAP
Idle control air value
Still runs the same.
Thanks to everyone and their responses.
It turns out it was the fuel sending unit. One of the tubes was loose and the base
of the connection. Once replaced all is good.
Ruben
    ar0517
    ar0517
  • Who's Online   6 Members, 0 Anonymous, 700 Guests (See full list)
