Tranny cooler
if you do a lot of towing you may want to swap in an instrument cluster from a 2500 or Esclade as they have the temp gauge for the tranny.
For whatever reason, GM has the the sensors in the tranny but no gauge in our dash.
I have heard a lot guys do this - supposed to be very easy.
All auto transmissions have a coolers but towing packages have a aux. cooler in front of the A/C condenser. Should be 8" x 5" and can be seen easily by looking down through the hood latch hole in front of radiator.
If you dont want to get the other guage cluster can you get a differnt guage and mount it in the cab....is the truck already wired for it or no?
Unless I'm just blind and/or don't know exactly what to be looking for...my '04 DXL has the towing package and KNP RPO code, but I sure as heck don't see any 8x5-sized (or similar) object anywhere in front of the radiator. I do see a narrower "radiator"-like thing (8x3?) but I'm guessing that that's the A/C condensor?
I'm suspecting that my KNP aux tranny cooler is exactly as how ChevyTech007 described it--the tranny lines going into the main radiator. FWIW--I thought I remembered a GM document stating that they were gonna eliminate the external aux tranny cooler on their fullsized trucks/SUVs starting in '04...which if valid would explain why I have the KNP RPO but no "visible" external aux tranny cooler on my truck.
The 8x3" cooler that you see,If its on the drivers side of the A/C condenser (kinda behind the drivers side headlamp) thats the power steering fluid cooler.
If you have "KNP" you have an auxilary tranny cooler,Plus you still have the standard cooler in the radiator itself. The fluid runs through both the aux.cooler and the radiator cooler.
All trucks with automatic transmissions have the "radiator transmission cooler" as standard equipment.
And No,GM did not eliminate the auxilary tranny cooler,My '04 has one as well as the '06's still have them.
I think I remember hearing that they eliminated them in the 05 and beyond Avalanche (for the tow package they made a larger in-radiator cooler). They are definitely still factory installed with the KNP RPO code. I bought the whole operation from GM Accessories and installed it myself to my 4.8 Silverado that didn't have the auxilary "air to oil" transmission cooler.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
