Suspension lift delete Z71?
heres a question ive been wondering about..
im set on getting a z71 truck.. but i also want to lift it. Am i wasting my money on the Z71 package if im going to swap out the suspension anyways?
are there pros and cons to buying a z71 vs a standard 4x4?
thanks so much.
If you plan on lifting it the only part of the Z-71 package that you'll end up keeping is the skidplates...which may or may not be cheaper to buy seperately...you'd have to get a price from the parts dept. then compare to the price of the Z-71 package.
I bought the 4X4 version (Sierra) and mine came with skid plates and just about everything else as the Z71. I like the 4X4 because I wanted the manual shifter (non autotrac). I'm not sure but I think the Z71 comes factory with the autotrac 4X4. I didn't need the Bilstein shocks either cause I replaced mine with ProComp anyway. Basically it's up to you and what you want. IMO, if you like the stickers, buy the Z71. If not, save a little $$$ to add to your 4X4 and buy that one. JMO though. :shakehead:
Hope that helped a little.
thanks so much.
For '06, only crew cab Z71s come standard with the Autotrac transfer case. All other Z71s have a manual shift transfer case standard, Autotrack optional. I cannot say that I am happy about that as I wanted the crew cab Z71 and a manual transfer case, but I had no choice.
For '05 the Autotrac was not standard on the regular cab truck. The Z-71 package also includes fender flares for '05 and I assume for '06 as well. I may be wrong but I think alloy wheels are also part of the package, as well as heavier tranny cooling. I ended up with the plow prep groug and trailer package, so I know I have all that there is to have in the cooling department.
I dont know why you guys are bashing on the auto trac feature..personally i think it works great!
It surely works great IF and WHEN it works. The issue is, these Autotrac cases are more prone to failures as there is a larger number of electronic/electrical components. And they are very expensive to fix if the failed component happens to be a major one. I had a manual transfer case on all other trucks before this one and never has any problem with any of them.
I read quite a few stories where Autotrac owners got stranded in the middle of nowhere due to malfunctioning switch, encoder motor, or some other ocmponents failure. This transfer case did not earn its nickname "Autocrap" transfer case for no reason.
if im buying a used car, how do i know if the autotrac is good or on the edge of going bad? are there signs? since its an 05' should i invest in the 100k extended warranty?
I believe the switchs have had trouble, ive never heard of any other problems with autotrac, i have it and no troubles.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
