Crab Legs
Chad H
Hey guys,
I am getting ready to pick up 2lbs. or so of crab legs. This is my first time to cook them but I have been told by several people how. I am going to boil in water with crab broil. Does anyone know the proper way to make drawn butter? Or is just melted butter? :bs:
2 sticks unsalted butter, softened
In a small saucepan, melt the butter over medium heat. Bring to a boil until the milk solids have separated and sunk to the bottom of the pan. Ladle out the clarified butter and place in a warm cup.
:flag: For better results drink beer before, during and after the process.... :bs:
The way I was told by a gourmet market was to run the frozen crab legs under cold water just to wash off the frost then bake them on a cookie sheet at 350 degrees for about 10 to 15 minutes. This basically steams them in the shell. The wife and I have crab legs at least once a month.
I have tried the boiling thing before but it seems the end results are better by baking them.
Crab legs are kinda like shrimp...REALLY hard to mess up.
I usually boil them in the setup I use for deep-frying a turkey. I'll cook a bunch of polish sausage, potatoes, corn-on-the-cob, a couple pounds of shrimp, and a couple pounds of crab legs....All in the same pot with a bunch of cajun seasoning/spices.
I'll eat that load of spicy goodness for 3 days solid.
Yeah but how many toilets do you go through in those 3 days?
CRAB LEGS, What is wrong with the rest of the crab that you wont eat it. Oh, must be that West Coast thing. Go get yourself some Maryland blue crab, some Old Bay seasoning and do it up right.
Yeah, it is work picking tham, but it is well worth it.
Crab legs, actually I think it's a foo foo thing.
Whole Dungeness Crab, no sauces, no shakers of anything, bucket of butter and a bib.
Same for lobsters, whole Maine/Mass, bucket of butter and a bib
BUT, the tomalley is left with carcass, some think they are good eats
Although I live in the desert, I do have the added expense of flying to San Francisco or Boston. Fly the critters here...no that's seafood in the desert.
I have a cast-iron stomach. The only thing that tears me up is coffee...No idea why.
I used Old Bay once. And that was too much.
Well, I just used some crab boil and they turned out pretty good. But, I think next time I will use a little bit more salt and some vinegar to soften up the meat on the inside. I have been thinking about ordering some alaskan king crab. Has anybody ordered some?
Guest chevydeerhunter
Just go with one of the boats on Deadliest Catch. You'll get your king crab legs and get paid about $15 grand to boot!
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
