Home Parking/Service Lifts
Now that I've moved out to the country I can finally purchase the item I've wanted for years- a home service lift. My barn has a 10 foot high "ceiling" (distance from floor to 2x6 crossmembers) so I can lift the Suburban around 4 to 5 feet high. At my old house, the height was only 8 feet in the garage, so it didn't make much sense to spend the money on a lift to only lift it a couple of feet.
Does anyone have any experience or recommendation on these lifts, usually described as "parking/service lifts"? There seems to be two categories, the very inexpensive lifts around $1900(probably Chinese made), and the better ones around $3100 (probably USA made).
If the cheap ones are good enough for routine maintenance, etc then I don't want to spend extra money. However, my life depends on the integrity of the lift. If the cheap ones will flex and bend as I tug on hard-to-remove parts, then I don't want them.
I feel at this point I have lived long enough to earn the right to avoid laying on my back with rust falling in my eyes!
Steve
Steve
You answered your own question. Is going cheap worth risking your life? My father paid 2500 and change for his 4 poster from some place in MA, American made quality.
A guy I know had one installed at his house and it was about $2800.00 and the company that installed it came here from Dallas Tx to do it. I watched him pickup his f250 ps with it and it seemed to handle it ok I think it was rated at 10000 lbs.
Don't know what you think about this, but another option might be a used lift.
Might be able to purchase a heavier-duty one from a closed shop that just needs some paint and maintenance, but you'll end up with stronger structural members than you'd get with an equivalent new lift.
Compared to a shop, you'll probably be babying it, so it should last forever.
Have to run the numbers to see, and it will be more work intially - maybe involving a factory tech to look it over for maintenance, but it might be worth it, depending on what's out there.
