Bed Payload Capacity
So I just put literally a ton of books in the back of my 1500. I think this is twice the rated capacity of my bed. Drove it for about 20 miles, 55MPH. I know it wasn't such a great idea, but was moving stuff from work to a customer that lives only a few blocks away from where I live.
Everything seems fine, but I was wondering if there is anything I should look for? Extra wear and tear. And was there any safety issues I may not have been aware of? I think my greatest risk would have been my leaf springs.
Oh, I do have Rancho RSX 9000 shocks if that makes a difference.
Your biggest issue when overloaded is braking (or lack thereof). Also, in emergency manoevers you can get unpredictable handling, such as when swerving hard the rear end may come around. I would not worry about what you have already done, it sounds like you took it easy.
I've towed a 4,000 boat where the trailer had no brakes a few times. I have had some experience with pulling some load. Of course with this nice 5.3L, can barely feel it... hehe...
I was worried since these trucks are called "half ton" and I did a full ton. Not sure what was going on.
My friend told me that I need to watch out for my tires actually. They are BFG All Terrain. Those weren't meant for hauling. But since they didn't pop, I should be OK in that area.
Thanks for the info.
OK, you asked-so here goes... You should NEVER pull a 13k bumper pull trailer with a 1/2 ton :cheers: If you do, you will break your frame about 2" in front of where your reciever hitch bolts up!!!!!! Yes, I am sure :crackup: You will also smoke those cheap little axle bearings at the same time :D This was one of the most expensive firewood loads I ever got for free!
by the way, I realize I was overloaded and a menace to society, but free firewood doesn't last long around here :(
the frame has a dowel hole about 2" in front of the reciever that seems to be the weak spot; check yours if you've been abusing your "wannabee one ton" :nono:
"13k bumper pull trailer"? I have a Class V or IV tow hitch. Whatever one is rated to pull 9k pounds.
But my main concern was bed payload. I figure they call them "half tons" for a reason.
Who was talking about a 13k trailer? Did I miss a post.
  • 5 weeks later...
sorry, I didn't check this post again. I was the greedy moron who filled up the trailer with firewood. yes, 13,000# oon the reciever. :cheers: OOOPS!!
