Hey everyone,
My four wheel drive was working fine and now all of a sudden its not engaging the front axel........The front axcel light on the floor shifter is not lighting up either.
My truck is an 88 gmc s15 jimmy 4x4........automatic with a 4.3 in it.
Any ideas what this might be??.......... :confused:
My 87' S-15 p/up is controlled by vacuum, passenger side inner fender, looks like a crusie control vacuum diaphragm. Thats where I would start looking, check the vacuum lines etc. I imagine there is also a vacuum switch that operates the diaphragm when you select 4X4.
Of course, if yours is the same as mine.
Thanks for the reply..........I will check it out today and report back....... :confused:
Well it turned out to be just a vacuum line that popped off under the hood.........I must have popped it off chaging the wires.
Anyways all works fine again.............thanks very much!!!!!!!................ :cheers:
