how to hook up amp- trailblazer
Looking to hook up a amp in my wifes Trailblazer, but not sure where i should tap into to get a signal for the amp. its a 02 trailblazer LTZ without the bose system. should i just tap into the rear speaker wires with a line convertor? the stock head unit has the in-dash 6 disc changer if it makes a differance, thanks for any pointers.
That's what I'd do if I wasn't replacing the head unit. Get yourself an infinity basslink, which has speaker-level inputs (along with line level inputs). It'll be the best $220 you ever spent. Includes 10" woofer, 10" passive radiator, and I think a 200w subwoofer amp. Has just the right adjustments on it too.
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
