Techron advice
Ok i bought 2 bottles of the techron cleaner stuff today (says put 1 bottle for 12 gallons of gas and my tank is 26 gallon so i figure 2 is what i need).
I am wondering how i should use this stuff.  I need to change my fuel filter soon and oil change is coming up in about 3 wks.
Should i add the techron stuff in say 2 wks then burn all that gas refuel change fuel filter and oil?
What do you guys do?
Thanks
Not 100% sure about techron but most claim to add same time as you change oil and I personally would add after the oil and fuel filter change.
Use the techron in the tank of gas just prior to changing the oil.  Reasoning for this is some fuel system cleaners deplete the additives in the oil.  Change the fuel filter at the same time as you change the oil. :devil:
Use the techron in the tank of gas just prior to changing the oil.  Reasoning for this is some fuel system cleaners deplete the additives in the oil.  Change the fuel filter at the same time as you change the oil. :D
:devil: Gonna have to use 2 bottles.  I usually get 1-20 oz and 1-12 oz., but you can use 2-20's anyways.  Unless you put it in at 3/4 tank..... :)
