1 day after having pads replaced and rotors turned the minimum to remove glazing, and flushing the fluid, on my 2001 gmc 4.3l v6 w code, 2wd, 4dr threw a dtc code of "B2600"???? all the dtc's i've seen start with a "P"??? even a "P2600" comes back non existent. what the heck??? any help would be great.
thanks.
All I could find
B2600 - Daytime Running Lamp Control Circuit (BCM)
B-Body
C-Chassis
P-Powertrain (the common seen)
U-Network
All I could find
B-Body
C-Chassis
U-Network
drl's work fine, do you think i could be a bcm problem? the brake techs bumped something? auto on headlights work good too.
thanks
All I could find
B-Body
C-Chassis
U-Network
thanks
/quote]
yep, thats what i get for using s short cut from that we hate drl's web site. the tech sait to remove the drl relay and bend over a certain pin, and drl's would stay off but auto on would work fine. i straightened the pin out, put it back and no more code, but now i have to do the dome lite dance again to shut off drl's, man i hate them things...........
