05 Silverado duel climate control swap
Alright I've got an 05 Silverado excab LS... it has the ugly dual climate controls with the two vertical control knobs. I bought the digital HVAC controls off of ebay that came out of an 03 Silverado LT. The controls are identical to what is in all of the higher class Silverado's... SS's.... Tahoe's and Yukon's. The fit and look is awesome.. but there's one problem. The HVAC control unit has two wiring harnesses connected to it. One for main power, temp, and vents... and the other harness is just for the fan speed control. The harness's for my original unit are labeled as "lt blue" and "black"... on the digital unit they are labeled "lt blue" and "gray". The lt blue harness fits perfect and works perfect on both... but the other is not so good... My question is how can I make this work? Do I need to hack up the wires and find the "gray" harness to make it work?.. if i go that route I would need a wiring diagram for my 05... where could I find that?. I haven't gone further in my dash than this and still haven't even taken out the OEM cd player so is there a possibility that the other harness might be hidden back in my dash panel?... The only reason I ask that is b/c my truck is not a base model and I wondered if maybe they shared wiring harnesses.
Thanks for any help.
  • 3 weeks later...
I am not exactly for sure if this would be what would be considered an easy swap. I have heard of guys attempting this before and basically it becomes more trouble than it is worth. The reason is there is a lot of extra wiring involved for this, even your airducts in your dash are drilled and sensors are integrated for the sensing of the interior temperature to allow the Auto feature to keep the temperature consistant. I personally dismantle some of these trucks for their interiors as kind of a side hobby and basically the dash harnesses are going to be different. If you really want to do it I suggest going and swapping out the complete dash harness which can generally be picked up by buying a complete dash from a wrecker or finding someone on Ebay like myself that offers these harnesses from time to time.
Thanks
Travis
you're going to be doing a LOT of work. :happysad:
new blower motor (manual controls use a rheostat for speed control, auto controls use PWM), all new ducting with the temp sensors built in (theres about 7 of them IIRC, and the wiring that goes with them), you'll need to install a cabin ambient temp sensor above the drivers seat in the headliner (no, its not the onstar mic :happysad: ), you'll need to install a new ambient light sensor in the dash (sunload sensor). New wiring harness to go with it......basically you'll need a lot of money or a donor truck. :happysad:
  • 3 weeks later...
you're going to be doing a LOT of work.  :D
new blower motor (manual controls use a rheostat for speed control, auto controls use PWM), all new ducting with the temp sensors built in (theres about 7 of them IIRC, and the wiring that goes with them), you'll need to install a cabin ambient temp sensor above the drivers seat in the headliner (no, its not the onstar mic :P ), you'll need to install a new ambient light sensor in the dash (sunload sensor). New wiring harness to go with it......basically you'll need a lot of money or a donor truck. :cheers:
So your saying 2 maybe 3 hours tops?... :D
I have also seen many attemp this mod and end up back where they started. Your gonna need some serious schematics and doner parts on hand. Good luck.
I don't think I would even try it and I have access to all the wiring diagrams and parts.
Honestly,I have the auto-climate control and I don't like it at all,If I could go back and buy my truck over again thats the one thing I would not have gotten.
i have got the old duel one with the verticle climate controls and i recently bought the digital one. i like how the digital one looks when i have it in however the plug that controls fan speed is different. i am not really interested in the auto feature or even if the temperature that the digital readout says is accurate. i just want the get the plugs to match and i have the original plug and i also have one with about six inches of wiring that will fit it the the digital climate control. is there are way i can cut the old plug of that has seven wires and connect it the the plug that has 10? i know that none of the colors match and i didnt know if some one could tell me what wire is what. i have looked everywhere and i cant find a picture that has them all labels so if someone could tell me it would be much appriated. or send me a link that has a picture
thanks alot
andy
oh by the way it is a 2006 silverado
thanks again
thanks alot
andy
thanks again
I was also wondering about this....
it is not worth the trouble to try and do this plus you will void the warranty on your truck as any dealer and GM will NOT warranty any service lights or wiring issues that will crop up as you have moidfied the system. the A/c control heads in all the new trucks are actually modules that commuciate with the BCM ( body control module ) and the radio and are programmed if you do succed in doing this the first time a GM dealership has to program your truck for a software up date for a problem the truck will not accept the program and cause error codes and may even cause the truck to not run anymore because the old software is earsed before the new program is downloaded to the truck.
and if the a/c control head is ever replaced under warranty, when they look up the parts it will come up with the manual control head and they won't warranty it as soon as they find out you messed with it.
if you wanted to have the Auto A/C controls you should have gotten a truck with them.
is it worth a couple of grand out of your pocket to repair your mistake and the lost down time of your truck that you just bought just to put in a COOL looking control head?
Good point.... :D
    RSTRICK
    RSTRICK
  • Who's Online   3 Members, 1 Anonymous, 593 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
