New from Wisconsin
Where abouts in Wisconsin are you from? Im located in Edgerton, myself. Thats about 30 minutes south of Madison just off of I-90.
  • 1 year later...
welcome I am from jackson, which is buy the new Cabelas store just north of milwaukee on the freeway 45 and 41.
I'm new here from Wisconsin and I own a 2004 :P silverado 2500 HD, 8.1 Allision. :banghead:
Welcome from South Texas (or North Mexico)...
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 249 Guests (See full list)
