Giving up on the snow..
burgundyz71
Well i m giving up on the snow for this year.. Here there calling for no snow to stay until early jan which means sledding is gone for the year..
So...................
Instead of buying my sled i m going to put half the money into a good used pickup and fix it up..
Now this is where i need some opinions..
I m looking for an early year S10.. Between 88 - 93 to pull apart and fix up.. Any suggestion on what year and what to look for... I dont know what year the 4.3 came out.. So if any of those years has one let me know cause thats kind of a want for me..
Thanks
S-10, yikes, the sound of that gives me shivers.  I HATED mine with a passion, it was a '92 2 door Blazer.  Underpowered, rough riding, too small, rusting hunk of metal with no interior space.  Yes, I had the 4.3L High Output motor (what they called it) that always left me searching for the high output.  The thing was worthless in any kind of snow or mud.  Had to have 4x4 on all the time since the wheelbase was so short.  If you were in two wheel and hit a patch of snow you'd be turned around before you knew what happened, put the thing on two wheels once when that happened.  They were very prone to rusting, every single Blazer you see running around these parts of that body style has rusted out rocker panels and fenders at the least, mine was pathetic with the rust, the way the panels are made just holds the snow packed with salt up in there, letting rust happen in no time.
If you can't tell what my recommendation is by now, you will soon get it.  Don't even think about one of these!!!!!!
The 4.3L was introduced in the S-10 in 1988.  Before that you would get the 2.8L.  There was no manual tranny option until 1989 with the 4.3L.
In 1987 you would get EFI in the full size truck, and it would be the body style from 2 generations ago.  In 1988 the fullsize trucks went to the last generation body style (but you probably already knew that).
I was originally going to use it for a main use offroad truck.. I put about 3 good scratches in my truck on the pass side that start at the mirror and go half way down the box.. And of course in a black truck the scratches are white so there horribly noticeable.. (pics to come)
So what i would like to do is build a nice offroad truck preferably an S10 just because the size on the trails.. I wanted to stay with GM and the 4.3 cause then i can get used to the parts on the engine and then work on my truck when it comes up to it...
Plus it gives me a chance to do some custom work on a used truck which i ve always wanted to do just havent had the time/money..
Mainly i was ready to spend 7500 bucks on my sled but with all the weather being so warm even if we get a cold snap here for a solid week *very unlikely when its supposed to hit +18 today* it wouldnt make a difference unless winter lasted until may...
If you want an off-roader, I would find an old chevy 3/4 ton w/ a solid front axle so that is pre-90's.  Throw a 6" lift on it and some 35's.  It's a little wider than an S-10 but you can run bigger tires and a 350 or 454 has more power.  Or, I would look into an old Jeep CJ
Buy the sled...ride it this winter....then put an asphalt track on it and wheels on the skiis and get some use out of it in the summer months.  Asphalt drags are getting really big in NY. It's going to make grass racing a thing of the past.
I've seen some where the guys race sleds across a lake, that's crazy.  I mean, if you let off the throttle, glug glug glug, bye bye sled.
I've heard of that.
I also heard of (Believe it or not) guys racing 4x4 rigs across lakes in Iceland. It was on TLC's "Extreme Machines".
Extremely modified 4x4 buggies running across lakes @ 70+ MPH. Let up just a little bit, and it bogs down and sinks.
If you are looking for this as mainly an off-roader, do not go with a fullsize pickup.  They are just too big and heavy for major off-road adventures.  I'd think with a little bit of work on the 4.3V6, a small suspension lift, and 33" tires you would be set.  And you could save some scratches on your good truck.  Sure the solid axle would be nice, but it comes at the disadvantage of having a much bigger truck, and it doesn't sound like thats what you want.
Kansas - Thats exactly what i was thinking about! I thought of the fullsize but the main downfall to that is size.. Thats why i wanted an older S10 cause there small enough to fit on the trails with some money invested in it the truck would do well for what i needed..
I just prefered the S10 cause then once i know how the truck runs i can work on my Z with no problems.. Plus i can get parts for next to cost *which helps in the long run*
Everyone will know what i buy when i get it.. ;)
Dude, your giving up too soon, winter isn't even hear yet and you want to sell, come on now it is the norm to not ride b4 January in the Northeast, last year was the exception.
I m not completely giving up on winter and snow.. I would just like to see some in the next few weeks.. If we get some good snow fall my sled is still there and i will buy it.. I have til Jan 1st to decide whether or not i want to keep my sled stored at the dealer.. After that they sell it...
Trust me the only way it wouldnt be not sold is if there was still green grass after xmas..
LETS GO SNOW LETS GO!
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 627 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
